Heating Problem. Help!!!!!!!
If you're lucky- Just tap on the servo and push/pull on the lever arm while someone changes the temp setting. I've had one stick in place and work fine after breaking loose.
I removed my bonnet and unbolted the bulkhead panel which made things much easier.
I also used this article to help me with mine:
http://web.archive.org/web/200811152...l/servos.htm#2. Whats the problem
