964 Forum 1989-1994
Convert C 4 box to C2
Old 06-20-2018, 03:47 PM
  #166
Dreamstate
Dreamstate's Avatar
I contacted Redtek for more info and they put me on their mailing list. If this doesn't come out public, I may need to make my own.
Old 07-06-2018, 01:40 PM
  #167
koenig_roland
koenig_roland's Avatar
hehehe...
Just another loveletter to the G64.00 :-)
https://www.youtube.com/watch?v=zqgG...ature=youtu.be
Old 07-19-2018, 08:34 AM
  #168
jeff33702
jeff33702's Avatar
I should have just put this here instead of another thread. About using a converted C4 trans in an actual C2.
For some reason, I cant copy paste the actual content...
https://rennlist.com/forums/964-foru...d-in-a-c2.html
Old 07-19-2018, 03:27 PM
  #169
HiWind
HiWind's Avatar
pasted for you Jeff (to copy, press [quote & reply] ie the {" "} on the bottom right then copy the text in 'source' format from the reply edit box that appears
Originally Posted by jeff33702
I'm considering a C2 tip. A few people have converted C4 transmissions to RWD but mainly those have been for converting C4 cars to RWD, not for installation in a C2.
Generally, are there benefits to running a converted C4 trans vs sourcing a C2? Gear rations more desirable one way or the other? I believe that the C4 trans would still retain some kind of LSD in a C4, would that old true if installing in a C2?
Obviously, the C4 box is cheaper - so I'm just trying to figure out if there might be even more benefit (other than cost) to use a C4 box?
Thanks!
Jeff
Old 07-19-2018, 08:30 PM
  #170
jeff33702
jeff33702's Avatar
Thanks - and I'm in IT, lol.
Old 10-06-2018, 09:00 AM
  #171
koenig_roland
another bit of finetuning and the uggly G64.00 performs good at the ring
PAOLOP (04-17-2020)
Old 10-06-2018, 10:02 AM
  #172
kos11-12
kos11-12's Avatar
https://www.youtube.com/watch?v=UQLo9O8rH6k
Master of the G64 around the Ring !
well done 👑
Old 11-01-2018, 07:23 AM
  #173
HiWind
HiWind's Avatar
Guy's I'd appreciate some advice please ... fitting my old C4 (now c2) box with conversion to a 3L SC road car. Considering the 3L with ITBs only puts out 200hp, would the C4 CVs and driveshafts work?
Also as there is no PDAS in the SC, will the gearbox work ok ie I guess it will like a non LSD (mech or hydro) version, right?
Old 04-17-2020, 11:33 AM
  #174
kos11-12
kos11-12's Avatar
Hi Jack,
I hope all is well.
It would nice to have some news from your C4 to C2 gearbox conversion,
Cheers
Old 04-17-2020, 01:26 PM
  #175
Mikke_Possu
Mikke_Possu's Avatar
Originally Posted by kos11-12
Hi Jack,
I hope all is well.
Cheers
Did you see this?
View this post on Instagram
The following 2 users liked this post by Mikke_Possu:
apanossi (04-17-2020), PAOLOP (04-17-2020)
Old 04-17-2020, 04:44 PM
  #176
kos11-12
kos11-12's Avatar
Cheers Mikke,
Yes thank you, exchanging a few emails with Technik at the moment, considering all options.
waiting to hear Jack impressions,
Old 04-17-2020, 05:55 PM
  #177
stutt911
stutt911's Avatar
I’ve test driven both cars, yet to buy one but really didn’t feel much of a difference. Seems like a lot of work to convert and wasted money
Old 04-18-2020, 04:30 AM
  #178
Mikke_Possu
Cheers Mikke,
If you can share more info from RPM Technik solution, I'm more than happy to hear.
Old 04-18-2020, 05:37 AM
  #179
ManuFromParis
ManuFromParis's Avatar
I've asked infos as well, here is the quick answer I received by email (prices blanked for confidentiality, just ask for a quote on your side).
I guess they will likely display the prices on their website soon.
Good day,
I hope you are all safe and well in the unusual times we find ourselves living in.
Thank you for your recent enquiry into the conversion of a Carrera 4 transmission to 2wd. To give some background, we have previously carried out Tiptronic and C4 to C2 conversions using G50 transmissions as these used to be quite readily available. As supply became harder and more and more costly, we started looking at this conversion in 2017 and after significant R&D, including scanning and 3D printed prototypes, we decided on casting our own end casing. We have modified various parts of the internals using state of the art technology and then assembled using all of the correct Porsche tooling to allow the full setup of the new diff as required. We built our first gearbox with the end casting and internal conversion and fitted it to a modified 964 with over 350BHP and the gearbox has been faultless. So we are now ready to offer this conversion. Parts are in stock and include;
- Gearbox end case
- LSD
- Bush set
- Cut and electron welding
- Indent for selector kit (early box only <1990)
- Gasket set
- Case blast and plating
- Labour
You will also need a pair of Carrera 2 driveshafts and diff flanges. Any shipping, delivery charges and/or additional parts required are not included.
When you supply us your transmission, we will strip, assess, clean (including bead blasting cases) and yellow and zinc finish as required.
The transmission will then be reassembled with all modified internals and a brand new plate LSD.
For this conversion we would need your transmission shipped to our workshops and we can then supply a parts list required so you can convert the rest of the car, and basic instructions on what else you will need to do.
Please understand this is a professional installation and whilst we would prefer to do the full conversion in-house we do understand in some cases it is not always practical to get a complete car to us, so we can offer to do just the gearbox conversion ONLY. We will only supply information to an experienced Porsche shop who have the necessary technical expertise, factory workshop manuals, and tooling to carry out the conversion.
This is not one for the home mechanic.
If you require any further information or to arrange shipping your transmission to us please contact us by return.
Stay Safe and Best Wishes,
The main question is about gear selection, so that you don't have to change the gear lever and mechanism, and I understand the refactoring of the C4 gearbox in this way would allow that.
To be confirmed, though.
Mikke_Possu (04-18-2020)
Old 11-25-2020, 03:17 AM
  #180
HiWind
HiWind's Avatar
Gents - are the flanges on the G64 box smaller than those on the G50 box (ie 100mm across vs 108mm)?
making new side shafts for the C4 to 2 convertion car - seems splines might also be different (C4 is 43 on flange part inside box)
Quick Reply: Convert C 4 box to C2
