Protective paint film
Having just had a full respray I'm considering getting protective paint film installed. I wondered if anyone had any experience with the various products available? Are there any downsides other than cost?
My local shop is Metropolitan Detail in Bellevue and their product came out quite well, I had the entire front end covered both wings and the entire hood so no seams, really like it.
The film qualities vary and it is all dependent on how well the shop prepped and painted the car. I have seen a lot of paint jobs lift when applying the film or years later. I like the Xpel products they have the least aggressive adhesive and don't look as though there is film on the car.
Allow as much time as possible for the paint to outgas before having film applied.
I was going to do this after my fresh repaint, but the guys that put the film on were not keen on fitting to non factory paint, as they were almost certain it would take the paint with it when removed. I have decided to just paint the car again one day if it looks that bad.
My car is for driving, not showing after all!!!
I have seen factory new Ferrari's loose clearcoat from poor paint work from the factory. If the car has been repainted it all depends on how good of a job they did prepping the surface before applying the paint. If they did the job properly it should not be an issue, if not???
1 Post
Most of my cars are covered. The xpel film is fantastic. It has saved my paint several times. If the car sits outside all the time I would not recommend it unless you don't mind detailing the car every 2 months or so. My cayenne turbo has had 3M since new and has always lived outdoors and 11 years later I finally removed it. The film had deteriorated badly but once removed the paint looks like new.
Keeping it simple:
Ensure paint has fully cured first
Do a paint correction to make it look perfect
Install either Xpel or Suntek film, have it done by a very experienced installer.
These 2 films are very clear and self healing. I think Suntek looks more "clear" and "less there"
Maintenance is similar to normal paint, but use a colorless synthetic wax (I use meguiars ultimate)
I treat my wrapped RS the same as any other car, wash, clean, clay, wax...
