Design 911 Rear indicator lens replacement tips?
#35
In hindsight, if you expected to just pry off the lens so easily without baking or any other preparatory method, then the build quality of these cars would suck if the lens just popped off. The adhesive may be old, but its on there.
Tread carefully those who attempt this in the future.
#36
Update - I glued the lens last night with http://www.selleys.co.nz/adhesives/h...plastics-glue/
It is nasty stuff to work with, irritating my eyes. Basically it's Super Glue. However it's a reassuringly strong bond. I had about 30 seconds to align the plastic parts, which isn't that difficult as the old glue line was very obvious and this is an OE part so the fit was great.
Tonight I will seal the join with a silicon and then 'bake' the other lens.
#37
I removed everything from the indicator, then put the body in the oven for 20 minutes at 100C.
I then used a screwdriver to pry the old lens off.
Following that I glued the new lens on. Placing is easy, just use the old glue trail as a guide. The glue I used set in about 30 seconds but I still left it clamped for 30 minutes to be sure.
Lastly I used a neutral cure silicon to fully seal the join. I'll post the pic with them in the car tomorrow.
