Design 911 Rear indicator lens replacement tips?
Subscribed
Need to replace the rear lens on my C4 too.
I will order the same lens on ebay.
Keep us posted about the way to remove and seal the lens.
Just my 2p. Believe it or not, the originals were pink too - not red as most expect. When I replaced my centre-section lens years ago, I found that the original was lighter than the pink replacement. The red colour (color) is achieved by an internal red filter and the white (reversing lights) use a green filter. Some, I think the rear fogs, had a louvre as well.
Typically baking is the go to method by a lot of shops for a lot of headlight modifications these days. The trick is to seal it well, you can find endless posts about shops not using great sealant and headlights will fog up and catch water.
Of interest to 964 owners https://www.facebook.com/groups/3670...8524989966591/
I've given up posting pics on Rennlist for the moment. Too hard.
I baked the light for 17 minutes with no luck so ended up cracking the lens and removing it physically. Using plastic cement to fix it plus a light coating of silicon to keep it leak free
Originally Posted by NateSaJack
John, saw the FB post earlier. Nice work. Def on my list of todo's. Shame the baking didn't work.
