Teardown begins. Suspension madness...
#1008
So while I was in there...I noticed the shroud cover was torn...why Porsche can't see fit to make one of these that doesn't break itself, is beyond me. So rather than spending yet another pile of money on a non-critical part that will fail in short order....I got out the black silicone, and let's see how black silicone (high temp oven gasket fix) works over time. My guess is this part will be entirely black silicone by the time it's done deteriorating.
#1009
Technical Guru
Originally Posted by Goughary
You mean to the 964 box? Or the 993 box? Is it lighter than the 964 spring?
Porsche used the same thermal paste you put between a CPU and a heatsink on a computer motherboard. I think it was more about heat transfer than it was electrical insulation?
#1013
Originally Posted by mystert
How does it run with the new coils?
Essentially this is not really an upgrade. The 993 coils do the same thing as 964 coils. They just do it more reliably over time. At least, this is the supposition. I'll know if I don't go trough another three sets of coils over the next six years like I did the last six...
#1014
After my ignition issues I'm going to just sit on my old Bosch coils for now. But when they give up the ghost I'll be sure to swap in these 993 coils.
Good looking work as always Goughary.
#1016
Old wires could be the case. But with so many 964 guys having issues and only rarely seeing 993 having issues...I'm going with "better design" or "better production" for the 993 coils.
Years ago- coils rarely failed. You see old 911 all the time with the old blue Bosch coils that they have been running for decades...the new silver coils suck.
#1017
Guess who came back today?
The spotted owl...
Needs a reinforced engine carrier, clutch master and slave and the hard line between. And while we are at it, the sills are being painted white...
The spotted owl...
#1019
New master and slave went into the owl. Plus the hard line the runs through the tunnel to the slave. The rear most fitting was seized, so that had to go. Making it new again one bit at a time. The clutch is buttery smooth now...
Sills next and all done.
