964 Forum 1989-1994
Lash adjust Go No Go approach?
Old 09-16-2015, 08:12 PM
JasonAndreas
Technical Guru
JasonAndreas's Avatar
Originally Posted by crg53
There is no magic tool that will give you spot on valve clearance of 0.1 mm every time
Kirk's tool is pretty close to "magic". Especially when it comes time to tighten the adjusting nut.
Old 09-17-2015, 07:07 AM
CRG
CRG's Avatar
http://www.stomskiracing.com/product...-lash-adjuster
used this with the engine out of the car and like it much better than other methods, with a dial gauge you can get it ***** on. will try it with the engine in the car in another 500 miles or so, have to use a small gauge with the engine in the car and #6 may have to be feeler method
kirk's tool looks pretty slick, i may pick up one and give it a try
Old 09-17-2015, 01:16 PM
Super90
Super90's Avatar
Very interested in this tool, but in my limited research, it sounds like using it in the car is challenging.
Looking forward to hearing your experience in that scenario.
Old 09-17-2015, 10:53 PM
Goughary
Goughary's Avatar
Default Lash adjust Go No Go approach?
Looks like the stomski tool just needs a smaller dial gauge to work in car right?
What's the best backside tool for use in-car?
Old 09-17-2015, 11:03 PM
C4inLA
C4inLA's Avatar
Huh? Two feeler gauges from hf ?
Old 09-18-2015, 12:19 AM
Goughary
Goughary's Avatar
No...the other way...dial gauge w z/block way...
Is there a "best tool" this way that fits over the backside from inside the car?
Old 09-20-2015, 08:58 AM
J richard
J richard's Avatar
To the OP, as was said valve clearance is a compromise between thermal expansion taking up all the slack and holding the valve off the seat (Burnt valves, worn cam and rockers) vs bits hammering themselves to bits. That's one of the advantages of hydraulic lifters. But the cam is designed with a ramp section that slowly (relatively) takes up the slack before opening the valve. There is a ton of inertia in the system at revs as well.
The easiest tool in my book is a 12-18" long feeler gauge. You can get them from snap on or a machinist supply. Bend it as needed, cut the end off when it gets chewed up. I find a curve works best. Set the crank position, loosen the nut/adjuster, slide in the gauge, tighten the screw to take all the slack/oil out, the loosen, snug to the guage and tighten the nut. Take out the blade. Takes a little feel but confirm it with a dial guage if it's your first time. Trying to stick it back in is hard on you and the tool in the car...
Old 09-21-2015, 01:34 AM
JasonAndreas
Technical Guru
I can't stress enough just how much of an improvement it is over every existing valve adjusting method; feeler gauge on the foot, backside method, z-block & indicator, bisected screw-driver, etc. And when it comes time to tighten the adjusting nut, you will know instantly if the screw has turned and not only that, it pretty much prevents it from happening. After the 1st two valves you'll go back and recheck but only because you can't believe how simple it was and think that you must've screwed something up. There is no guess-work, it is a micrometer.
Quick Reply: Lash adjust Go No Go approach?
