Rear Wiper Switch Cover
I ended up using mine for a fan switch. I put a piece of matte black vinyl sticker on it so its just 'blank'
- Hazard Light Switch (944 613 235 00)
- Door Latch Switch (951 613 147 00)
- Rocker Switch (for clearing the "!" light) (964 613 202 00)
Would the wiper switch in the dash be a suitable place for either the Door Latch Switch or Rocker Switch?
I know those are bigger switches than the rear wiper switch, but if the switching mechanism is the same (same poles, connections, etc.), I could just run the wiring from one of those two center console switches to the dash where the rear wiper switch is, and just use that (maybe cover up the wiper logo so it looks acceptable), no?
Is that not possible?
The door latch switch and the "!" switch are likely both momentary type switches, whereas the rear wiper switch is likely a latching switch. I would think the Hazard Lights aren't momentary, so that might work.
I mainly want to know where to put these switches
As part of my backdate-ish project, I need to relocate the following from the center console:
Nah, probably not. Or at least not ideally. If I'm you I'd grab the rennline stereo blank that has the cutouts in it. It's made for this.
Radios are overrated and the CDR220 is especially bad. I have one in a box that was in my car. I prefer the reno in my 89, at least it looks the vintage part!
But yes if you do a radio then blank won't work. Not sure where you relocate those switches. Maybe the rennline lower dash delete with a switch panel mounted on it below the dash...
I think I could maybe put a switch to the left of the headlight switch (where some cars have the adjustment dial thing). Could I relocate the door lock thing in the driver's door somewhere? (Would that look stupid?)
Don't know where to put the warning light disable thingy though...
Somewhere on the internet, I recall seeing a switch in the e-brake plastic insert thing. That's kinda awkward too, though. Sigh.
What does Singer do with the other two (they put the hazard button next to the headlights and ignition)?
