Window Motor Help
Window Motor Help
I'm in the process of installing an express window roll down feature into my 964 using a kit.
I've got the LHS door installed no problem and works pretty great.
I've hit a snag with the RHS motor.
The motor which is inside the door has a plug connected which you tap into with the kit.
However, i can't remove the connector from the RHS window motor.
Has any one changed the motor for their electric windows and has some experience removing the connector? It won't budge and it feels different from the LHS connector (can't see it as it is inside the door).
Here is a picture of what I am talking about (not my car):
Good instructions there but not applicable to my issue with the motor itself.
Thanks though!
