Turn Signal but NO Parking Lights
I need help diagnosing an electrical problem. My left front turn signal works but the parking light does not (right side both work fine). I replaced the dual-filament bulb (both filaments were ok) but still no change. Should I replace the plug portion that the bulb goes into? I also checked the contact points but since the turn signal works fine the bulb seems to be getting power. Any thoughts or similar experiences?
Just did the same on mine. Same issue. The contact points are really finicky so it took a few minutes of wiggling and testing before they worked. It's worth the patience if it's the same thing. I also used a screwdriver to adjust the metal contacts to help but be sure to have no power to the light or it may short and blow a fuse.
