Will they fit!
Will they fit!
Hey,
It's another one of these threads! I'm on the hunt for a set of Gemballa Lemans and I found a set in Germany. I know the rears will fit as Rennlister 964George has the same wheel/size on the rear, however his are 18x8 ET50 on the front, the ones I've found are 18x8 ET47.
So am I right on thinking the 3mm difference on the offset won't matter? Or is 18x8 ET47 no good?
p.s. if anybody has any advice on shipping wheels from Germany to UK I'd be much appreciative!
Chris, You should be fine as long as your camber/caster/toe settings arn't too out.
Still seems to be a little bit of room left.
They should fill the arches nicely, Gemballa's are great wheels.
I'm not quite sure on the offset of the wheels currently on the car. But it's booked in at Unit11 to get the geo set up, so can just tell them the offset/size of new wheels and they should be able to set up for new wheels?
