Most depressing Porsche photo
Well, I think this is convinced me to get a fire extinguisher in my car. Can anyone recommend a good one? I see Rennline sells some, a bit pricey. Look nice though.
Suppose I could just make one.
I'd rather have in mounted in the back, maybe use the seat belt bolt holes in the middle to mount a bracket. Seeing I removed them, would be a perfect place.
I found this on here:
But I'd rather it bolt down.
After a good friends b5 s4 burnt to the ground on its maiden voyage after a single turbo conversation, ill always have a fire extinguisher in the car. Two down in a week.. Brutal.
My advice would be don't bother. A small cockpit handheld will do sweet FA with an engine bay fire. By the time you notice, the situation would have progressed well beyond its capabilities. The sheer amount of latent heat and combustibles would not be bothered by the small fart those things give out. It would help you out with a fuse box or electrical fire (if you have a cut-off switch), but engine fire, forget it - I'd wager you'd get burnt trying and achieve nothing. You'd need a few of the large 12ltr jobs to stand a fighting chance.
It's there to give the driver an increased chance of getting out before everything goes super-nova. It can take a bit of time for Marshals to leg it over to your car wreck carrying large capacity cylinders. There are systems on commercial vehicles that do something similar, and focused more on trying to put the fire out. The capacity of the cylinders here is much larger.
Originally Posted by robt964
As said above, it's all about buying you more time. A plumbed in system like you mention, frequently seen in race cars, will be a lot better but still far from any guarantee of saving the vehicle. That's not what they're there for.
It's there to give the driver an increased chance of getting out before everything goes super-nova. It can take a bit of time for Marshals to leg it over to you car wreck carrying large capacity cylinders.
Thx
At 25 years of age, there won't be an original hose on the car that doesn't need replacing
Enjoy your weekends fellas/
