DME not readable by Durametric
Hi,
Still can't start the car unless I manually close the first relay in the DME relay (same with all 3 DME relays that I own)
I can't read the Motronic DME using Durametric unless I start the car. I presume that it should normally be readable with the key in the ON position. Looking at the DME relay with the cover off, the first relay (DME, injectors) does not close with the key in the ON position. Is the DME normally powered with the ignition key in the ON position ?
Thanks in advance,
Enzo
Thanks in advance,
Enzo
Just a quick note to say the problem was the alarm module (92863710403 part # in my case). It's under & behind the hood hinge on the passenger side in a right hand drive car.
