964 Forum 1989-1994
replacement guage lens?
Old 06-13-2015, 10:33 AM
tcsracing1
tcsracing1's Avatar
Default replacement guage lens?
I am sorting out my 964 turbo... given there is more traffic here then turbo forum (on production #'s alone) i fugure i would try my luck here.
Some of the lenses on my guages are either cracked or have hazing....
What is the cause, what is the fix and where do i get the parts?
Old 06-13-2015, 11:35 AM
Streetdaddy
Streetdaddy's Avatar
I need a gas gauge lens , too. Will be listening
Old 06-13-2015, 12:26 PM
Duck
Duck's Avatar
Not sure where to get them, but I sent my gauges to North Hollywood Speedometer. They cleaned and replace trim rings and glass (on 2 gauges). They may be able to sell you just the glass. I just mangled the trim rings when I tried taking mine apart.
http://www.nhspeedometer.com
Old 06-13-2015, 03:05 PM
TouringTeg
TouringTeg's Avatar
x2 I had my oil pressure gauge rebuilt by NH and they did an excellent job. They stock a lot of parts for these gauges so they may have them.
Old 06-15-2015, 09:10 AM
freno a mano
freno a mano's Avatar
I polished mine and now they are perfect.
Old 06-15-2015, 09:24 AM
DobermanDad
DobermanDad's Avatar
First thing that came to mind when I started reading. Unless they're crack, just polish them. Probably could even take the lenses to a jeweler or someone like that and have them do it.
Old 06-15-2015, 03:06 PM
svendsen1
svendsen1's Avatar
I got a price for the lens from Pelican and NH Speedometer. Pelican was about $10 cheaper so I went with them. The hardest part about replacing it is going gently with the compressed bezel that keeps the glass (or plastic) on tight.
Old 06-15-2015, 07:13 PM
David A
David A's Avatar
For the dials alone, contact him. He takes a while to reply but he does.
http://porschedials.com/?page_id=13
Old 06-15-2015, 08:59 PM
4Play
2nd Gear
4Play's Avatar
I'm able to manufacture the lens out of tough plexiglass like material. I made a few for myself and for a friend. Please email me and I can send you photos of before and after. They fit perfectly.
mbarwinski at hotmail.com
Old 06-16-2015, 05:07 AM
StopLookGo
StopLookGo's Avatar
i had a local glasscutter cut some for me. cost me a few bucks.
Old 06-16-2015, 09:31 AM
NoSub Dan
NoSub Dan's Avatar
Isn't there a clear film coating on the inside that can be pealed off? Then you can reall get in there and clean them. I seem to remember something like that. They are hard to get to though.
Old 06-17-2015, 11:55 AM
Derek911
Derek911's Avatar
There is a plastic film that can be removed I believe on both inside and outside faces, but I could not clean the film off. The price for new lenses are so cheap why go through the effort of trying to clean them. I purchased a new fuel gauge lens from Pelican and the diameter was smaller than the original. I almost sent it back but I made it work. It was just barely big enough to fit behind the lens frame, any smaller and the edge would be showing. I'm not sure why the diameter was cut so much smaller than the original. Like someone else mentioned...You can get this glass cut yourself locally. Take the lens out, take it to a glass shop and they will make a replacement. The pelican lens is just a cut piece of glass, nothing special that can't be replicated, in fact, it is thinner than the original plastic lens.
Old 06-17-2015, 01:47 PM
cobalt
cobalt's Avatar
Received 1,926 Likes on 1,166 Posts
There is a clear plastic on the inside. Usually they start to delaminate and it looks bad as a gap opens. It can be removed however, it is intended to keep shards of glass from flying around in case of an accident.
Old 06-17-2015, 06:50 PM
tcsracing1
tcsracing1's Avatar
do you need to buy new seals?
Old 06-19-2015, 01:26 AM
Derek911
Derek911's Avatar
To my recollection the only seal is the rubber gasket on the outside of the gauge that seats against the instrument panel. It was glass/plastic sandwiched between the metal ring and the gauge, no seal on the glass. I didn't take a seal off when I removed the original lens.
Quick Reply: replacement guage lens?
