Spacers for Turbo 3.6 lowered on PSS10
4 Attachment(s)
Hello,
I have a 1994 911 Turbo 3.6 and want to ask your opinion on what spacers I should install. I have 5mm spacers on the way and 7mm spacers on the way from FVD. This is how my car sits currently on PSS10 its pretty low, the rear wheels fill out nicely but they are very close to the trailing arm .7mm distance. The rear tyres are 295/30/18 on Speedlines (10.5) inch width. The front tyres are 225/40/18 on Speedlines (8.5) inch width. What spacer size do you suggest for the front is 7mm on stock studs adequate or too extreme. What do you think of 5mm for the rear and 7mm for the front ? will that be a nice look. |
Your car looks perfect as it is. No need for spacers. If you decide to get spacers make sure they are hub centric the hub only extends out 7 mm so you will loose the support and centering if you go with flat spacers. If anything possibly 3mm up front but not necessary.
Drooling! Car looks so sweet. Can't wait until I''m in the market for wheels.
I would suggest 7-10mm.
Make sure you get longer hardware for the appropriate spacer. |
There's a 964 Turbo subforum. I'd make a thread there and point them to this thread.
