Adjusting the clock...
Yup that's the one. If you press it, it should move in small increments. If you press and hold it it goes around faster.
If nothing is happening then something is wrong with the switch or the clock.
Maybe someone else can chime in because I don't know anything about either.
Most likely someone pulled the clock out before and pulled the small wire out of the connector on back of the gauge.
