Leakdown results question - Rennlist - Porsche Discussion Forums
964 Forum
Sponsored By:
Sponsored By:
Old 06-04-2015, 07:03 PM
LPMM
LPMM's Avatar
Default Leakdown results question
I had a PPI done and following the results and the seller's asking, I decided to pass. The seller is now coming back to me asking me what my best offer is. There were a few things uncovered during the PPI but the biggest "problem" seems to be the leakdown results. The test was performed cold and the numbers are (from cylinder 1 through 6): 7% - 12% - 8% - 5% - 30% - 6%. The shop found no obvious leak and believes the rings have lined up so that it is going down the cylinder head, past the rings, and into the crankcase.
How bad is it with cylinder 5 at 30% while others are consistent but much lower? Trouble for my wallet in the no so distant future?
LPMM is online now
Old 06-04-2015, 10:42 PM
Mixter
User
Mixter's Avatar
The test should be done with the engine at operating temperature.
Under 5% - awesome
Under 10% - good
Under 15% - acceptable
Over 20% - bad news for your bank account
As per this thread.
https://rennlist.com/forums/964-foru...mpression.html
Mixter is offline
Old 06-05-2015, 02:52 AM
Steve Weiner-Rennsport Systems
RL Technical Advisor
Steve Weiner-Rennsport Systems's Avatar
Under 5% - awesome
Under 10% - good
As per this thread.
Thats pretty darned accurate, but JUST as important, the technician performing these tests must listen for the source of any observed leakage, otherwise its a waste of time.
You really need to know whether excess leakage comes from the valves or the rings/cylinders/pistons.
Steve Weiner-Rennsport Systems is offline
Quick Reply: Leakdown results question
Contact Us About Us Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
