g50 nose on a g64 transmission
I may have found a g50 gearbox to make my car a c2 in the future. Is it possible to change the front part of the gearbox from the g50 to my g64?
I ask this because the g50 flange to bolt it to the engine is broken. thanks |
I belive they are the same as ive known someone go the other way, problem will be finding one of those case ends. Unless the box is cheap id maybe hold out for a 964 version
@jevvy964 thanks
anybody else? |
Interested in seeing how you go about this. I think Ninemeister made a C4 into a C2. Seemed like a lot had to be done.
You can buy the front-end part from Porsche. costs new around $500
Part No.: 964.301.301.01 or 950.301.901.10 http://dcauto.gotdns.com/illustration/index/28260937 |
I think the OP is actually talking about the bell housing. Which is the same c4 vs c2 afaik the only differences are between early SMFW and DMFW cars.
It converts without issue.
Cuts both ways. You will need to but a Tailcone but the one you take off is equally rare and valuable. Should be close to a wash. |
so there is a difference in gearbox between flywheels. I have an early 5th month of 89 c4. Are there any c2's with single mass flywheels?
Originally Posted by dimma man
(Post 12336803)
