Passenger Door Seal?
Its not broken they shrink over time a common occurrence
coupe
91153193102 left 91153193202 right
targa/cab
91153193142 left 91153193242 right
$11.58 ea from sunset
coupe
targa/cab
Any time. BTW when you go to replace it you will need to carefully pry the black metal strip off the door. put tape down first and use a plastic pry tool. Might consider buying a few extra clips just in case you loose some. IIRC there are 7 per side. part number 99979950307 they are usually rusty and only $ .53 ea.
