Has anyone seen this Oil pipe crack before and fixed it?
Prior Owner "Repaired a hole in the Oil filler neck with JB Weld Goop. I found it performing my 1st Oil change myself. Did a PPO & my ex-Mechanic
said nothing about it. See Photos - leave any advice. (Yes, I've seen the other post regarding cracks in other cars filler necks.)
Oil Filter Removed... Hey what's THAT?
Upon Closer inspection....
Its soft and sticky like loose caulk.
Mine has a few deep cracks around there but it is only in the thickly applied under shield thats sprayed on. It's shrunk a bit with the heat. I recon yours is the same. Dig it out and check, worst case you're back where you started.
I had a hole in the exact same spot and I used JB Weld to seal it. I used a long flat stick (like a popsicle stick) on the backside of the oil fill tube to make sure it was nice and smooth.
It looks like they used some kind of silicone caulk.
It appears to be part of the "body". See PET Pic 801-26 which lists the repair part (thread) for the filler neck
I changed my oil today and my car has the same JB weld looking substance on the base of the oil fill tube. I can't imagine every owner getting the same idea and using the same thing, so this must either come from the factory like this or done at the dealer as a technical service bulletin.
Mine is the same. I've read elsewhere that if the filler neck ever broke, the official repair recommended from Porsche was to use this "goop" to seat the new one, thus making it quite common. I have not heard that it was added to all cars based on a TSB, but it certainly could be the case.
