What grease for shifter assembly?
I plan on installing my RS shifter along with new bushings this weekend. I couldn't find any mention of what grease to use down there. What are you guys using?
Technical Guru
At the very beginning of the workshop manuals you'll see a bunch of yellow pages that list all the previous TSBs that correspond to the existing model. If you dig up any of those TSB that cover shift installation they all say, "Shift rod linkage and bushing must be lubricated with grease (Optimally HT or similar) in sliding areas."
Technical Guru
That stuff is Optimoly NR (000.043.110.01) which is a CV grease. Its been awhile but I vaguely remember that stuff having a smell that you would probably prefer not having anywhere near the passenger compartment, even under the rubber cover. Optimoly HT (000.043.004.00) is a copper based grease.
Technical Guru
I imagine anything that is compatible with plastic and metal? Optimol MP0 would probably be better? I would only hesitate with NR because it smells/out-gasses.
I did a friend's car first, his is a 94 so it already has the oval bushings. I made a tracing of the hole so I have a template for my car. I'll be doing mine this week.
