964 Forum 1989-1994
Speedometer Light Bulbs...Which Ones?
Old 01-20-2015, 07:12 PM
August West
August West's Avatar
Default Speedometer Light Bulbs...Which Ones?
Did a search to no avail but wondering if anyone can tell me which light bulbs are used for the speedometer.
I've gone to Pelican and there's the blue base bulbs at .9W or the beige base bulbs at 1.5W...
Thanks in advance!
Old 01-21-2015, 06:11 AM
james_marshall
james_marshall's Avatar
Id like to know too - one of mine has gone .... being a bit lazy by not taking the speedo out to check :-)
Old 01-21-2015, 10:29 AM
Rocket Rob
IHI KING!
Rocket Rob's Avatar
If memory serves, the lights have different color backs. The speedometer uses the light bulbs with the gold /beige backs. I believe they are the 1.5w which is part number 999 631 027 90
When I had my speedo out to repair the odometer, I replaced all of my bulbs. I bought both the 1.5 and the 0.9w just to be safe but only used the 1.5.
Old 01-21-2015, 02:12 PM
james_marshall
...again, without sounding too lazy.... how many bulbs are there behind the speedo to replace?!?
Old 01-21-2015, 02:25 PM
August West
Many thanks, Rocket Rob!
Old 01-21-2015, 04:10 PM
Rocket Rob
IHI KING!
Rocket Rob's Avatar
Three behind the speedo (see photo below, "borrowed" from the internet). I bought 10 of each and keep them in a drawer, in case I need them. The cost of the bulbs is cheap.
Old 01-21-2015, 04:38 PM
August West
Only three in the speedometer? Maybe I don't need bulbs after all. Just seems a little dim in some places around the dial...oh, well, just ordered up a handful of bulbs anyway...
Old 01-21-2015, 04:49 PM
jg291446
jg291446's Avatar
0.9w bulbs are required. The 1.5w bulbs are for the working light. I heard using 1.5w instead of 0.9w is not good.
Old 01-22-2015, 03:24 AM
Twood
Twood's Avatar
I replaced mine with LED's. White for the light and red and blue for warming signals.
happy to supply the types of LED's if required
Old 01-22-2015, 04:32 AM
PhatPhlatSix
PhatPhlatSix's Avatar
Did you mount the LEDs on the lamp-holders, or did you just insert them into the holes?
Old 01-22-2015, 04:45 PM
August West
So, which is it? I've ordered up some beige 1.5 Watters and now I'm not even sure they're the right ones.
I sure wish the correct wattage bulb was correctly delineated in the PET and Pelican catalog.
Old 01-22-2015, 05:04 PM
boxsey911
boxsey911's Avatar
PET shows that the dials have 1.5W and 0.9W bulbs. As far as I can tell the 0.9W bulbs are the green base ones used for the warning lamps. There are a lot of these in the clock. The 1.5W bulbs are the yellow/beige ones that are used to illuminate the faces of the dials. I replaced all my original yellow ones (because some had blown) in all five dials with the 1.5W beige ones, two years ago. I bought them aftermarket and they worked out at about $1.50 each. Had no problems with them at all.
Old 01-22-2015, 07:39 PM
August West
The best answer yet from Boxsey! What you said makes total sense and it looks like I got the right bulbs for any dial illumination issues I may have.
Thanks!
Old 01-23-2015, 01:09 AM
Twood
Twood's Avatar
I ordered led lights with a 8.4D base in blue white and red- they are quite common on the Chinese websites. I could look up the supplier if required.
they fitted straight in with very minor modifications
Old 01-24-2015, 02:12 AM
Twood
Twood's Avatar
Default LED Instrument Lights
Just found the link where I bought the LED's for my instruments:
http://www.bl-led.com.au/store/index...roducts_id=250
Quick Reply: Speedometer Light Bulbs...Which Ones?
