What did you do to or with you 964 today?
#155
It will also help me with local track sound limits
#157
Handbrake shoes, new clutch slave cylinder and rubber hose, full hydraulic bleed including being sprayed in the face with brake fluid... Erh!
#159
Broke the shift linkage as I got to the work parking lot... then had her towed to my mechanic.
The shifting was feeling stiffer and stiffer... I should've stopped driving.
And not use the redline gearbox oil. Mobil1 stuff original going in from now on.
#160
Lots
Front bumper off, doing a thorough clean down there. Also finalizing the fitting of the hard top (it's been a really long time coming; been driving with it on, but sans the side gaskets and a perfect fit).
Also planning on pulling out the last of the parts for the convertible top from the area behind the front seats. Think the transmissions/motors.
#163
Popped my new door cards in. Had the bins done in black basket weave. Had a bit of trouble on the color for the cards, but ended up with high quality leather. The colors are a bit off and I'm at a loss for a solution. Perhaps a deep burgundy dye for both the seats and door cards will get done eventually.
For now, I plan to drive. KWV3 gets installed in a couple of weeks...
