My new exhaust system!!
#32
No worries if it's too late and already on the car. We can forgive you, but only if you post a sound clip of it running
2.5" piping after the merge collector is perfectly ok
#33
Here is a graph of what headers with long primaries like those pictured will do to the torque curve of an M64 engine with stock cams. The long tube headers are the red curve, stock 993 heat exchangers are the green.
#34
I recently purchased a set of exhaust system from Japan. They're called Volcano. I have no affiliation with them, but thought I'd share with the community about these guys. The welding work is quite amazing, and I can't wait to put these on.
This system is a full race with headers and muffler, as well as heat exchanger. All I can say right now is that it's very well put together.
Here
Here
#35
Yes!
I went through those guys. They're very helpful. I talked to Mathieu, he was very quick on getting back to me even though our time zone was 12hrs different.
I'm installing it this weekend.
#36
PM sent
#37
installed
So I installed the exhaust system on to the car over the weekend. Everything fit like a glove, and I mean like a tight glove. It's on there very nice and tight...no wiggling whatsoever. Again, the piping work is a beauty to look at when they're on the car. Took the car for a few spins over for a few hours, and I have to say it's a huge improve from what I had before. I had Fabspeed cat bypass along with a primary bypass. The sound is on the higher note than before and at WOT, it's just amazing. I also updated to a new Steve Wong chip to accommodate the header. Gain or not, I definitely feel there's more pulling from bottom all the way to redline. Anyways, here are a few pics and videos.
#44
Hehe...the camera audio does not do its justice. No...I'm pretty sure there are no leaks. The sound is not for everyone. Definitely not for you if you think it's obnoxious
As for the heat goes, there's warm air pumping out. Just not super hot. So I wouldn't do this mod if you live in Alaska.
