Nose bearing leak
Nose bearing leak
Last year around this time I did a reseal. My engine was really grimy, but never left a drip, so I was really pissed to see that now after all my hard work I've developed a leak big enough to drip. It's coming from the crank area and dripping down the case, so I figured it was the crank seal. I took everything apart and wiped it all down, the next day I came out to see that it isn't the seal. I guess the o-ring on the nose bearing is failing. The only right way to fix this is to split the case, my engine runs fine and that is just not happening right now. I searched around and found that this is pretty common with the early 911 guys, so yesterday I ordered one of these
http://www.mobileporscherepair.com/t...ring-solution/ Hopefully this stops the leak until a rebuild some time in the future. If it doesn't, I guess I'll just live with the leak for now.
Has anyone dealt with this problem or have any thoughts, I would love to hear them.
Some of the 911 guys have developed various types of rings that go around the #8 bearing behind the pulley that allows them to seal up that joint with RTV or an o-ring.
http://forums.pelicanparts.com/porsc...-leak-fix.html
