Spare tire
Never thought about it really, so once you've changed wheels like the rear in the image above, where are you supposed to put it? I can't image it'd fit in the frunk?
Honey, would you mind holding this on your lap for the next 1.5hrs
IHI KING!
The three times I've had to use my spare, its always been to replace one of the rear tires. The owners manual says to take one of the front tires and put it on the rear and then use the spare on the front. I just put the spare on the rear and then put the flat tire in the rear. I was by myself so I didn't have to worry about the passenger. By the way, the stink from a blown tire inside the cabin is intense.
I've heard mixed reviews on the spray stuff - but can't hurt to keep it in the frunk just in case - better than nothing (maybe?).
Once you have inflated the spare tire, how do you deflate it?
I have removed the valve core from mine, but it doesnt fully go back to its original shape, so I cannot get it back into its cavity in the front.
Also, I see there are 2 valve stems, on opposing sides. One is a normal tyre valve stem.. the other has a rubber cap like a brake bleeder cap.. what's this one for?
mike
mike
IHI KING!
To deflate the tire, remove the stem and be patient. I have thought about putting a ratchet strap around the tire to speed the process.
As for the extra valve stem, not sure.
Tried putting 2 ratched straps around circumference of the tyre, but that didn't work well... starting to wonder if my spare tyre, has goop inside it stopping it from deflating fully!
In reply to Dr. Mitch:
Plus, the "regular" spare won't clear Big Red / Black upgrades.
Actually, yes it will, but only if you carry and mount a 1" bolt-on spacer, which I do. Since I was one of the first to mount Big Reds back in the early 90's, it was obvious then that the regular inflatable spare would not directly bolt on. I hit on using a 1" bolt-on spacer and found that that works with my outsize Alcon 332mm front rotor and Big Red caliper. Of course I not only have to carry the spacer with me in the trunk but also five extra steel lug nuts to mount the spacer. But it works and it all fits in the trunk. The spacer lays pretty neatly over the spare when its stowed away.
I've had to deflate my spare a couple of times by pulling the valve stem core but ultimately you'll likely have to find some strapping or bands to pull the tire back into it's original uncompressed form. But it certainly can be done and it can be done repeatedly. Of course once you sufficiently de-compress the spare then you put the valve core back in, but not until then.
