Inexpensive interior upgrade
Technical Specialist
Lifetime Member
Lifetime Member
With a fixed tail, there's not much need for the circular raise/lower tail switch on the C2 dash, so for $6 I got the Turbo part (964.552.157.00 color code 1DB, only color black). Taped the connectors that came off the switch and pushed them back, and installed the plastic piece. While it fit fine in front, apparently the sides are set to catch on something I don't have, so I cut off a few pieces of the box and taped them down on each side to build things out a bit, which works. Here's a picture:
Technical Guru
Except for the metal clips on the side there is nothing holding the change cubby in place on my RSA.
Sideview of the cubby
bottom side view of the center console
