964 Forum 1989-1994
Does anyone know this 964?
Old 11-06-2014, 07:51 PM
Pcarforlife
Pcarforlife's Avatar
Default Does anyone know this 964?
Thinking about making an offer....
http://www.ebay.com/itm/Porsche-911-...US_Cars_Trucks
Old 11-06-2014, 07:57 PM
R6XTERRA
R6XTERRA's Avatar
beautiful car...
Old 11-06-2014, 07:58 PM
vagluv
vagluv's Avatar
If that car is legit you might as well just hit buy it now
Old 11-06-2014, 10:23 PM
creaturecat
creaturecat's Avatar
Wheel wells not body colour in '94?
Old 11-06-2014, 11:31 PM
LPMM
LPMM's Avatar
Originally Posted by Pcarforlife
PASS! It was listed before http://www.ebay.com/itm/1994-Porsche...p2047675.l2557 same seller "turbotwo" and same VIN# WP0AB2968RS420429
Something is fishy with that car... While in the new listing the seller had them aligned (hood still not completely right), if you look closely at the old auction, you can clearly see that both the hood and engine lid don't align properly. They are way off as seen here.
Also, the color overspray on the underbody suggests that the car has been repainted, it should be grey with no body color.
Old 11-07-2014, 01:28 PM
ClaytoVR
ClaytoVR's Avatar
Good catch! When you can see imperfections like that over the Internet they are usually much worse in person. Too bad, such a rare bird.
Old 04-23-2016, 06:49 PM
Bertram964
8th Gear
Bertram964's Avatar
I was looking at that car... Did notice the misaligned hood and engine lid. Did not notice the overspray until you mentioned it. Nice catch! THIS is why I joined Rennlist! Thank you.
Old 04-23-2016, 07:17 PM
P-daddy
P-daddy's Avatar
I could be wrong but all the 964s I've seen all have a hint of body color on the underbelly. The wheel wells should not be black. Pepboys rubberized undercoating?
Old 04-24-2016, 10:30 AM
porsche mania
porsche mania's Avatar
I'll second that, my guards red car looks just like that underneath and its definately mot overspray!
Old 04-24-2016, 11:04 PM
Danger
Danger's Avatar
How many wide body, non turbo 1994 C4s were sold in the US? I ran across a local guy with one, this morning.
Old 04-25-2016, 03:41 AM
motts
motts's Avatar
Old 04-25-2016, 11:40 PM
u7t2p7
u7t2p7's Avatar
Interesting that there were 767 RSA's between MY93-94 but only 720 total C2 coupes (MT and Tip) for the same time period. Figure if 60% were MT's, that means approx 450 C2 coupes vs 720 RSA's. One reason why many believe the price differential is out of whack, even for a "limited edition" model.
Old 04-26-2016, 09:34 AM
cobalt
cobalt's Avatar
Received 1,929 Likes on 1,168 Posts
We really have to stop using this chart the numbers are not correct. If you want accurate 964 widebody info visit Norbert's site.
http://turbo-look.com/
There were actually 267 C4 widebodies made and as far as the rest subtract 60 units for all MY vins. Adrian counted the first 60 vin numbers which were test mules and never sold. So vins all start at 0061 not 0001. There were also only 335 US spec 94 turbos and there were a total of 460 both C2 and C4's manual and tip made for 1993 and only 140 C2's in 1994 although rumor has it some of the 94's were M718 coded which would make that number less. So far fewer C2's built in 93 and 94 than all the RSA's if you subtract the number of 93 C4's made. The RSA registry claims only 620ish RSA were made but assuming none were M718 coded the number should be closer to 648 however I believe about 20 or so of the 94's had the 718 code.
I found also that only red 964's seem to have a hint of color to them when painted from the factory. Also the widebodies for some reason seem to come with a black coating in the wheel wells from the factory. Not sure why they do but not the narrow body cars.
Old 05-02-2016, 04:47 PM
Pcarforlife
The turbo look checked out perfect! The mis-alignment at the hood and trunk lid was not closed fully while taking pictures. I took it to the local Porsche specialist and paint metered every body panel, all factory paint, all original. (even the tires are original).
Old 05-02-2016, 07:18 PM
P-daddy
P-daddy's Avatar
BIN before someone else jumps on it!
Quick Reply: Does anyone know this 964?
