clutch pedal not returning
Hello, I am noticing that my clutch pedal is not returning the full way after pressing it in. the clutch still dis-engages and engages. but is slow to return to the normal position.
Any ideas ? low on fluid?
where do you check this and if it is low what is the correct replacement ?
thank you for any help.
John
John
I have the same issue. Seems worse when hot. Roll pin seems fine. I removed my apparatus and replaced the master cylinder and slave soft line. Still the same. I image it's a combination of having a bit of air in my system and maybe my slave being time to replace. Although I can't be sure. Good luck sorting it out.
