964 Forum 1989-1994
Anybody ever replace windshield washer nozzle?
Old 09-26-2014, 05:38 PM
Streetdaddy
Streetdaddy's Avatar
Default Anybody ever replace windshield washer nozzle?
I finally tracked down a pesky water leak down to the washer nozzle. It leaks inside by getting around a foam seal on the passenger side.
Has anybody replaced one of these? Is there a rubber seal underneath ? Do i just need the zozzle itself.
Old 09-26-2014, 11:48 PM
justin-in-athens
justin-in-athens's Avatar
There is a seal there, but its really not much more than a thin layer of rubber. It will pop up with a little bit of pressure from the bottom side. Be prepared to replace the Oetiker/pinch clamp with a like replacement where the hose connects to the nozzle.
Old 09-27-2014, 05:09 AM
Harry Apps
Harry Apps's Avatar
And don't forget the heater wiring if you remove it.
Old 09-30-2014, 11:54 PM
Streetdaddy
So i take off the air intake and pop it up from underneath?
Old 09-30-2014, 11:57 PM
justin-in-athens
You should be able to squeeze your hand under the cowl from inside the trunk without removing the air intake.
Old 10-01-2014, 04:24 AM
neffets
neffets's Avatar
I had the same leak, put a small layer of butyl band underneath it.
Quick Reply: Anybody ever replace windshield washer nozzle?
