92 C4 brake bleed experience seeking advice..
Hello all.
Decided to bleed the brakes on my car last night. Little background on my car. its a 92 with 45,000 miles on it. I had the clutch bled by a shop and they noted that the fluid was nasty and I should consider a full flush asap.
I printed out the DIY from this site and I have the book.
My trouble is this.. I was unable to get steady good flow from any of the caliper nipples. I bled all 4 corners 5-6 times, including removing nipples and cleaning them out. My pressure bleeder was pressurized to 20lbs. I did eventually see clean fluid at the right rear caliper and the brakes "feel" better. But the lack of flow causes me concern.
Fluid in the lines is most likely from the factory as the bleed nipples on all 4 corners of the car still had black paint on them. It seems as if the rubber caps did as well.
Thoughts?
Thoughts?
Don't think you can get 20 psi if the overflow hose isnt clamped unless thats boogered up. I forgot to clamp mine last week and it wouldnt take 3 lbs.
Do you have trash in the bottom of your fluid reservoir?
overflow tube was clamped. Bleed nipples were removed, blown clear with air prior to bleed. I also tried to bleed with nipples removed and still had slow flow. Perhaps its just the way these cars bleed due to all the stuff that is in line between the reservoir and the calipers.
It would be interesting to see how the rears bleed with the proportioning/bias valve removed or gutted.
I seriously doubt that you had "Factory Brake fluid" In your car. Brakes need to be bleed every 2-3 years, more often with track use, to prevent moisture buildup and corrosion. When I bleed mine, it takes 3-4 minutes, to fill a pint bottle at 20 lbs. pressure, at any of the bleeder screws.
