Primary muffler question
I have a stupid question for you. I apologize in advance!
I am in the process of removing a primary muffler by pass and I am curious as to the orientation of the primary muffler when it goes back in? I am then installing a G-pipe to see what sound difference is?
if you would like to text me a pic or me text you a pic that would be great! 612-806-4382
Kris
Kris
Thanks for the pic(and the tip) Vandit!
I am curious on the back side though? Both pipes coming out look the same? There are brackets welded on the engine side of the muffler that the straps attach to that I am curious about?
You shouldn't need to remove the bumper.
I believe there are a couple of tabs on the canister that lock into the bracket, then the big straps hold it in place.
