rear blower motor :job done
Only to tell you ,that it is now working ,as new
Cost ? : not £500 for the whole assembly not 130£ for the motor only but only 3.20£ for one ball bearing I only changed the front bearing ,which takes the brunt of the fan vibrations The rear one was intact It took me some time to do it ,though.... next time it will be much quicker |
Good job! What were the signs that told you there was a problem with the bearing?
intermittent grinding noise ,becoming less and less intermittent !!
putting the end of an an iron bar on the blower casing and the other against my ear ,I could clearly hear the problem was coming from there nad was not something to do with cams /valves |
you have a ball bearing size that you can share with us?
of course
size is 8x16x6 mm 8 mm is internal diameter 16 is outside diameter and 6 is " thickness " i bought them from simplybearings.co.uk (no interest) word of caution :expect to spend quite a bit of time to resolve the numerous issues you will be faced with : -assembly is blocked by sharp chisel strikes :be careful not to damage them too much or you will struggle to re assemble -as bearing is shorter than existing bushing , you'll need to use several washers to compensate -it is likely that the shaft is slightly worn where the bushing used to be ;you do not want the inner race of the bearing to spin around the shaft ;carefully choosing your washers (pressure on the inner racing) will help - the existing bushings are held in place by sort of a ring clamp ,which is supposed to work one way only ;you will need to bend the "fingers" of this clamp to be able to insert bushing and bearing Plenty of small problems to solve ,but good fun !! |
Good description; did you take any photographs? I'm sure others would like to see them.
i am cross with myself :i did not have my camera to hand !!
should have done |
i'll take the motor out of the car and post pictures of the motor
I won't take the motor itself down for ..obvious resons but it will be better than nothing Please bear with me a couple of days |
1 Attachment(s)
here are a few photos
you can clearly see: - the washers to compensate for the difference in thickness between the old bushing and the new ball bearing - the way the motor frame pasrts are assembled /l cold chisel strike ;I have carefully filed the locking bit (minimum pl4ease) - the re assembled motor frame parts : cold chisel strike +a touch of jb weld on top I hope it helps nb : all is clearer when you do it !! Ps : impossible to upload my 4 files :failed 4 times sorry |
Thank you for taking the time to pull it apart again!
Originally Posted by FeralComprehension
(Post 11302508)
.. Gregg |
