The silly little question thread ...
#781
Hi there!
I've only had my car for a week now and I'm learning a lot.
I've downloaded the US 964 parts catalog from the US Porsche site. Is this the same thing as the PET that everyone refers to?
If not, where do I get a copy and are there other online catalogs/reference sites that I can be pointed to?
Thanks!
Thanks!
#783
That's awesome. Thanks. Very much like the one I've used for my BMW's.
#785
You can elevate one side of the car and do that side, then the other, but honestly, it's much better to drain the oil and do the whole job with the car sitting level.
#786
#788
understood...will drain the whole lot....have gotten pretty far into my small DIY attempt....about to loosen the engine mount (white arrows pointing...if I loosen these the engine falls?) and AC brackets...do I just place a jack under the engine case to support it?...nothing under the tranny or different for a C4? thank you
#789
#791
oil pressure sender manifold
I spent almost an hour trying to lever the sender manifold out...nearly broke a finger and my back is aching like a biatch....is there some secret way to pull out the manifold from the engine case?
#793
I can very slightly wiggle the manifold. But there is no sign of oil leakage around it. Was hoping I could replace the O ring but it will not budge/pop out...
#794
#795
The pressure gauge needle wobbles up and down randomly....as if a screw is maybe loose... I re-tightened all electric connections but still behaves strangely... purchased new OEM VDO sender from Porsche and trying to install by pulling out manifold but it will not budge...guess no choice but to find 24mm crowfoot and try to unbolt old sender...
