The silly little question thread ...
#1711
Can anyone tell me what the bolt (item 30) in the diagram below actually bolts into. When I got my car item 31 was missing and I though I would replace it. Having got item 31 and 2 x item 30 I can't see what holds item 31 in.
#1712
On older ones the were screws that expand plastic tabs that held that cover on. My handle was broken and ordered a new one the new one had machine screws and brass ferrules that the machine screw went into.
#1714
Thank you. That would make sense. It looks like my unit is missing the captive brass ferrules.
#1717
Is there an easy way to remove the oil pipe (#54 in parts; engine to oil filter) connection at the engine? It is obscured by the heat exchanger covers.
Thanks for all the replies.
#1721
I haven't done it yet but am planning to use an induction heater to heat the nuts only. It seems to be a more precise method than a flame, unless someone has a reason not to do it this way.
#1722
I haven't had much luck with induction heaters since they are so hard to get in there. I find that soaking them with a penetrating oil several times over a few days prior helps. If not then heat with map gas. If you brake them hopefully they don''t brake at the base. If there is some meat left I find these help in the right size. https://www.grainger.com/product/36T...!469717995576!
If it brakes at the head it is an expensive tool but well worth the investment but Steve Stomski makes a nice tool for drilling them out and tapping them.
#1723
IHI KING!
I used penetrating oil and heat via a mapp torch. The induction heat would work also but I don't have one. Be careful not to rush and break the studs.
You will need a 6" long M8 allen wrench to reach the internal exhaust nuts and a swiveling 13mm socket for the others.
I bought a set of Snap-on wrenches and a swivel 13mm from Sears. Note, this was a few years ago, when Sears still had tool inventory in my local store.
8mm allen wrench socket - https://store.snapon.com/Hex-Long-mm...r-P631886.aspx
#1725
