When cleaning ISV how to tell if it's operational
So I have the common hunting idle problem with my 91 C4 w/LWFW. I removed the ISV and cleaned it thoroughly. When looking inside the gate was partially closed which looked like it should based upon the pictures I saw on the forum. My question is how to I know if the ISV is operational? Should I be able to move the gate or another part? The gate wouldn't budget but I wasn't using much pressure for fear of damaging it. Thanks.
You can hear and feel it click... I believe with the key in the on position you can test it by unplugging the plug.
On the bench I think you can test it as well with 12v power.
Plenty of threads on this... try the search function.
Also check your AFM (Air flow meter) and FPR (fuel pressure regulator). Try the search.
