Stripping a 964 for a ready for paint
Replace your door felts(£85.85) & seals (£40) while you're at it......
and check all your body work supports.........
Remove anything that's not metal..!
I had a bare metal resto done last year - absolutley everything came off. Before you know it a long list of replacement parts follows you around everywhere - from heatsheilds and all new rubbers to screws and fixings. £2.3k in parts for me (including a new o/s front wing).
Worth it though - until you write it off 6 days later on the way to Le Mans!
Thanks Lemass, sort of over it now - thankfully...
Jack, if you're interested I have the replacement parts list of every OPC item and part number that I replaced during the respray.
Marcus
Marcus
Front & rear PU support rails and retaining strips, a myriad of speed fastners, screws, nuts and washers. Check and more likely replace PU heat shields. Check rear alloy bumper and supports for corrosion, nearside fixing point very often badly corroded requires a repair or new bar to maintain integrity.
I've just been through a similar exercise and could not believe how many items are on the rear bumper section. I will save you counting, there are 178 individual items IIRC!
Parts required for my respray:
All screws/hardware to fasten all lights to front bumper
All new hardware for front Splash-guards
Part to repair left door release
Drivers side stipulated door handle
Left Rear chassis support bracket
"Porsche" emblem on bonnet.
Right Wing -support bracket
Left Wing-support bracket
Left-side clear Reflector between Fog and Indicator Lights
Rubber Seals for Left & Right Shark Fin
Rubber Seals for left and right side-skirts
Left 1/4 panel support brackets (tubes) rear bumper
Right 1/4 panel support brackets (tubes) rear bumper
Wheel Centre Caps-4
Lower Rear Bumper supports-2 parts pressed steel
Retaining Bracket/strip on bottom edge of rear bumper-
Left door seal
Right door seal
Left & right Wing seal (scuttle)
Front Wipers
No. Plates
L&R window pillar door felts
Locking Panel Decals 3-off
Replacement seal for sunroof #1
Replacement seal for sunroof #2
Left Rear Bumper Piping/Seal
Right Rear Bumper Piping/Seal
Front Bumper Retaining Strip
All brake calipers refurbished & resprayed
........oh, and get yer alloys done, as you would'nt wear old shoes with new suit!!!
Wheel Centre Caps-4
Left door seal
Right door seal
Front Wipers
No. Plates
bolts,screws,washersand spire clips for front and rear bumpers
and other parts
REAR BUMPER SUPPORT £44.96
SPEED NUT £0.48
SCREW X4 £5.12
LOGO £23.96
LOGO £12.48
OVAL SCREW X2 £2.20
FRONT SCREEN RUBBER £98.28
HEADLAMP RING £35.05
FRONT SCUTTLE RUBBER £6.44
FRONT WING SPEED NUTS X20 £60.00
HEADLAMP RING BOLT X2 £0.56
LEFT KICK PLATE £23.94
RIGHT KICK PLATE £23.94
DOOR MEMBRAME £24.94
PIPING £2.80
PIPING £2.80
SEALING STRIP £54.72
COVER STRIP £11.27
COVER STRIP £11.27
COVER STRIP £7.84
COVER STRIP £7.84
SUPPORT X6 £14.28
SPEED NUT X4 £1.92
SCREW X4 £2.96
HEXAGON HEAD X6 £1.32
SPEED NUT X6 £2.22
HEXAGON HEAD X4 £1.92
WASHER X4 £9.52
SCREW X8 £1.92
WASHER X8 £1.92
WASHER X4 £3.76
SPEED NUT X18 £4.32
SCREW X8 £4.16
SPACER X18 £16.92
PLASTIC NUT X20 £1.80
D5A CLIP X20 £47.60
B4D GROMMET X20 £4.40
N/STK WASHER X10 £2.40
D1B SCREW X20 £4.40
and other parts
SPEED NUT £0.48
SCREW X4 £5.12
LOGO £23.96
LOGO £12.48
OVAL SCREW X2 £2.20
PIPING £2.80
PIPING £2.80
COVER STRIP £11.27
COVER STRIP £11.27
COVER STRIP £7.84
COVER STRIP £7.84
SUPPORT X6 £14.28
SPEED NUT X4 £1.92
SCREW X4 £2.96
SPEED NUT X6 £2.22
WASHER X4 £9.52
SCREW X8 £1.92
WASHER X8 £1.92
WASHER X4 £3.76
SPEED NUT X18 £4.32
SCREW X8 £4.16
SPACER X18 £16.92
D5A CLIP X20 £47.60
D1B SCREW X20 £4.40
Mad isn't it? - all those parts, and I forgot about the bumper mounts and supports. When we stripped down to metal plenty of nightmares requiring custom fabrication and repairs - usual front scuttle, rear window bottom corners totally gone but hidden under the rubber seal, front wing wheel arch front too gone to repair so a new one fitted....
Replacement is my new avatar image shot at Millbrook for Classic Cars magazine late last year. Still have the salvage of the previous. Trying to sell off the grey sports seats and interior at the moment...
thx
jcx
Exactly that jcx but there is two Allen bolts in each shut. You'll need to trim the bottoms slightly to get them in and use soapy water. Take your time and it will be fine
As for the soapy water... Is that to lube them for sliding in?
I see design911 advertises these with two widths... 6mm ish and 4mm ish. What is the difference? Is one better than another?
Thx again
Brill thx Tom. My wings still have the spotweld in place in the shut. Does that need to be 'released' (read broken) to get the old rubbers out and new rubbers in?
Thx again
Thx again
