My track car suddenly sounded very loud. The noise was from the CAT so I took off the heat shield. The O2 sensor is completely gone, wiring and all. Has this happened to anyone else?
My engine was rebuilt and I changed the CAT to a newer spare I bought cheap. Maybe it wasn't correctly torqued.
An emerging thought is that Singapore didn't need these sensors so only a bung was fitted. Apparently you can use a 14mm spark plug in place of a bung. Appeals to my wallet.
It does look as if all you lost was an O2 sensor plug. The tinwork shows that you have the factory delete plug where the wiring would normally pass through into the engine compartment for a car equipped with an oxygen sensor.
Thanks. I'll search for an image to see what you mean.
