964 Forum 1989-1994
The quest to resolve a pesky flat spot, with help from Steve Wong
Old 11-12-2013, 06:26 AM
jorijori
jorijori's Avatar
This is the thread that you referred to me about adjusting throttle cable:
https://rennlist.com/forums/964-foru...tle-cable.html
Pictures by JasonAndreas:
Old 11-12-2013, 09:12 AM
Soderblad
7th Gear
Soderblad's Avatar
Look in the end of this thread to see the WOT switch in aluminium.
If there interest contact me and we will work it out.
https://rennlist.com/forums/964-foru...or-needed.html
Old 11-12-2013, 11:47 AM
Lorenfb
Lorenfb's Avatar
"After a couple of hours with the car, Paul reported back that the throttle microswitch was in fact broken and the throttle was not opening fully"
Very very basic Porsche info that all good UK Porsche mechanics know,
i.e. hardly any great revelation from here in the USA given the symptoms.
Furthermore, a search on Rennlist or a thread indicating the problem would
have pointed in the same direction. Furthermore, there're many UK Rennlist
sponsors, e.g. 9m (NineMeister), that are very knowledgeable about 964s
and have far more insights than some of the so-called tuners here in the USA.
Old 11-12-2013, 12:36 PM
jorijori
jorijori's Avatar
Soderblad, how much? where do you ship it from?
Old 11-12-2013, 01:00 PM
jack.pe
jack.pe's Avatar
Cheers Paul, good to know about this...!
I'll get Nick to check this as part of the rebuild..
Old 11-12-2013, 01:21 PM
ras62
ras62's Avatar
The plastic cam actuator is only used on the later plastic inlet cars. Alloy inlet have a different throttle body and microswitch mechanism.
Old 11-12-2013, 07:28 PM
PaulW_964
PaulW_964's Avatar
Huh? I didn't say it was a revelation, I don't get your point. Steve Wong had already suggested what the problem was. My mechanic was just investigating that was the case with mine and fixing it for me. The main reason for my post was to help others, which everyone else seemed to get... Thanks for your response anyway
Old 11-12-2013, 07:53 PM
August West
August West's Avatar
Unless we have a difference of terminology, I'd have to disagree with the above statement. My car is a February 1990 build with the alloy inlet manifolds and had a plastic cam for actuating the WOT microswitch...are we speaking the same language?
Old 11-13-2013, 05:24 AM
ras62
ras62's Avatar
Apologies, I was referring to the wrong switch!
Quick Reply: The quest to resolve a pesky flat spot, with help from Steve Wong
