replacing rod bolts without splitting the case.
anyone else do this?
Apparently my (ex) independent repair guy did. I have the receipt. |
Now I know what they mean when they say to a mechanic, "you must be a magician"
Keith |
Yes, it is possible (and common) to replace the rod bolts without splitting the case. However, you can only use a torque wrench to torque them, you cannot use a stretch gauge which (in my opinion) is the correct way to torque the rod bolts. Given that the engine was assembled using a torque wrench, there probably is no negative to doing using only the torque wrench method.
thanks guys
is it easy enough to change the rod bearings at the same time? |
Yes, we do this all the time.
The rods get resized (rebushed if needed) and ARP bolts installed. We tighten the bolts to the specified stretch spec and measure the torque required to reach that value. If new bearings are to be installed, the rod journals are measured so the rods can be adjusted for correct bearing fitment. Once re-installed back onto the crank, these are tightened to the measured torque value above to ensure proper tension & stretch on the bolts. |
thanks Steve.
They charged me for splitting the case. 85 hours of labour for a reseal. 16000 dollars The case was not split. Hopefully the rod bolts and bearings were actually replaced. And it leaks like a sieve. |
Originally Posted by creaturecat
(Post 10894910)
thanks Steve.
They charged me for splitting the case. 85 hours of labour for a reseal. 16000 dollars The case was not split. Hopefully the rod bolts and bearings were actually replaced. And it leaks like a sieve. PM me about who did this, please. |
