Alternator parts number - help
I need to replace bearing of my alternator. my car is convertible 964 year 1993.
I find a good source for repair kit :
http://www.aspwholesale.com/index.ph...1015&Submit=Go
BUT they ask me the Bosch alternator part number. i cannot provide because i did not remove the alternator yet.
I assume the alternator is original.
I find on internet several numbers
0 120 468 029
0 120 468 125
Can someone help me and confirm which should be the correct part number?
Chris
0 120 468 029
0 120 468 125
Chris
Part number from Porsche 964 Katalog: 964 603 156 01
But I have seen other derivations: 964 604 156 AX
Here's a write up from Pelican if you haven' seen it already:
http://forums.pelicanparts.com/porsc...r-rebuild.html
Technical Guru
Originally Posted by bo11I find a good source for repair kit :
[url
[url
http://www.aspwholesale.com/index.ph...1015&Submit=Go[/url]
thanks you very much for your answers. indeed i needed the bosh part number.
011Pervy gave me 0120468125
and from pelican it is 0 120 468 029
Pervy you confirm that the number is for late modele 964?
Chris
Chris
RL Technical Advisor
Jason,......that VR is now $245. It certainly still a good buy if its not made in China.
Technical Guru
The Bosch Aftermarket Catalog is available online. You can even compare the specs between part numbers. Just enter the old number and then click on the replacement number.
