Rear light lens with water
run a bead of clear silicone sealer at the point where the lens meets the body of the unit, also make sure you have the little foam seals on the bulb socket or silicone seal them as well
Lenses are notorious for separating from body
there are breather hoses that shd be attached from the centre rear light to each of the side lights
they are clear plastic and shd help with condensation (i think) so check yours are attached.
