Hi guy's,
My car has just gone off to the body shop for paint. I am getting them to weld up the side repeaters in the wings (fenders). My question is this, has anyone modified the indicators in the front P.U (the one's next to the factory indicator) to work as the side repeater?
I can see that the moulding has something that looks like it could be messed with. Anyone done this mod, if so how?
Thanks in advance.
Mark
To answer your question the bulb holder used for the side repeater can be used in the side reflector. Just need to drill the hole out then connect the wires to the front indicator. Obviously you'll need silver bulbs if you have clear lenses.
The rubber shroud on the bulb holder will hold it in place on the reflector.
