The 964 engine bay is ugly
#121
The 964 engine bay may be ugly....
It sure can cook though!
#123
#124
For me it’s simply doing the blower bypass and getting the pad keeper or something similar. Would love to reroute the AC lines, put a new pad, and remove the cruise but it will happen only if the engine ever gets dropped, otherwise too much hassle.
Yeah but my excuse is that I am contributing to a better weight distribution.
The A/C lines aren't worth removing the weight savings were insignificant and a PITA to put back in case you want A/C again IMO. Although the front condenser and fan are worth removing. Just cap off the lines if you do.
#125
Hi cobalt, I have the plastic intake on Mine. I was just meaning to cut all the little bits off to tidy it up before I either paint or coat it. It turns out robt964 has done it, Its the look I'm after.
#126
Rather than clean engine bay, I'd call it de-clutered...
I'm looking to swap to the later plastic intakes, does anyone know if there is an advantage to swapping to the later throttle body too and if it's even possible?
#127
agree. Threads like this are what gives Porsche owners a bad name
9SIX4-C4 (01-17-2021)
