Which center caps fit Cup 1 wheels tightly?
I have a set of Cup 1 wheels, the non-OEM ones in 17x7.5" front / 17x9" rear fitment which were on my 964 when I bought it. They have Porsche crest center caps, but the caps don't snap tightly into place. They do snap into the wheels, but they are not held flush against the wheel. Instead, they are able to move "in and out", so that sometimes they stick out a little from the wheel, and sometimes they sit flush against it. The little clip tabs on the back are obviously too long or something...?
Can anyone point me towards a center cap which will fit properly? I would prefer the ones with the black recessed Porsche crest, not the colored/painted Porsche crest. Or perhaps, something different....? Thanks!! |
I think that happens with the non OEM wheels, the caps don't fit right :(
Here's a set of cup II's 18" wheels , they are aftermarket wheels and look at the center cap, it doesn't fit right, someone told to sand the center cap on the inside edge and it might fit better, haven't tried it yet? :cheers: |
My Cup 1s are replicas as well. I wrapped a bit of duck tape around three of the prongs and this has help them a tighter fit and held them in place. You don't need much just a couple of loops around each.
Cheap and easy... two of my favorite words :) |
It also depends on the cups. I had a set on my Cup replicas that fitted so tightly so one of them broke when I removed them before a re-paint of the rims.
Thomas |
I have factory center caps with gold crests. I don't have the link here at the office but they look similar to the ones on this page, lower left corner. They are all metal and look and fit perfectly in my Cup 1s. If memory serves, they had a 928 part number.
http://www.hubcaps.org/911.html No affiliations. |
I have the ones with the monochrome crest and they fit my OEM cups fine.
I can only find cheap looking plastic crap - to fit my reproduction cup 1's.
Are the OEM center caps different to the replica center caps that are out there, as far as diameter, mounting clips, etc? Anyone compared them at all?
Originally Posted by GoKart
(Post 10389640)
It's not the center cap that's different from the OEM and after market, fotting wise, it's the wheel that different , that's why the center caps are either loose or they will not go all the way in... |
I'd love to get my hands on a set of these 7.5/9" Cup I reps. Do they have a good offset too?
I found that on the rep wheels that the metal centre caps fitted (I guess these are OE) but any plastic ones (including OE plastic ones from later wheels) just rattled around.
P.s. Yes Vandit the offsets on the reps (52 and 47 IIRC) work nicely. |
I'm reviving this 2013 thread because my question is the original title: which center caps fit Cup 1 wheels? -- in this case, OEM Cup 1 wheels.
Please confirm part numbers. Do the later caps meant for 997 fitment also work on OEM Cup 1 wheels? |
Bump. Which center caps (specifically the monochromatic/black logo on silver field) fit the OEM Cup 1's?
Will these fit - 993.361.303.05? |
993.361.303.00 is listed in PET as fitting option code M402 in MY 92 and forward (M402 is Cup 1 wheels in 16"). The last 2 digits being 05 from your p/n is interesting in that usually this just means a part has been superseded with an updated version. So in theory your p/n should be fine but I don't know why PET still shows an older version.
Anyway, as has been pointed out original Porsche caps fit better than aftermarket and AFAIK almost all wheels from Porsche that fit the 964 also fit a bunch of other models (notably the 993 and 986) and all accept the same size hub cap. I certainly hope so at any rate as I just bought a set of 4 off eBay to go on my Cup 1 17" to replace the coloured crested caps I currently have (I stupidly gave my plain black logo ones to the guy that bought my Sport Classics that had come off a Boxter). IMO I think the plain black logo on silver looks better than the coloured logo. |
Originally Posted by hamah
(Post 11244088)
