Race / Track Pad recommendation??
#31
After years of using Pagid Orange and Black, I decided to try Hawk HT-10 pads and have been very happy with the results. The Hawks don't take as long to come up to temp and have a more progressive feel like a street pad but still give me the plenty of braking power. They also don't seem to be as hard on my rotors. No affiliation.
#32
I'll clarify - for street use it's my arguement that (beyond the bedding issues and noise) race type pads are a mistake.
At calm speeds and during calm use, a guy might not notice a difference, however some here have indicated that they enjoy "spirited" road driving. It is my contention that during these outings, when a person really wants precise control of his slow pedal, the race pad will usually not be at temp - thus the use of the term "inconsistent".
I depend on the brakes for all sorts of things beyond simply slowing down at a stop light in town. Balance, chassis setup, dynamic trail braking and simple threshold braking all play a role - if the pads are grabby, slick or merely not the same every time I ask them to do something - something could go wrong at precisely the wrong time. Some may not notice these inconsistencies, others will.
I would not run race type pads on the street.
The only "spirited" driving I do happens on the track anyway.
would anyone slide their car sideways on a street road at 150kph with trees on the side on the side of the road? does anyone do heavy braking from 230kph to 80kph to take some street corners at 100% speed? i think people's 'spirited street driving' would not come that close to track driving - particularly those that have never done any track driving.
#33
i don't disagree with any of your comments except that i doubt anybody's 'spirited road driving' would come close to track type driving.
Colin mentions the use of Pagid Blacks for hill climbs - where the driver has no real opportunity to get the brakes up to temp prior to use. Makes sense.
#34
Fair comments if you use your car on the road a lot, of the few miles I do on the road, too much hassle to change the pads. Plus I drive steadily on the road in the 964. I really dont find RS29s quite so noisy, but I guess I may have been lucky. Once they are bedded in properly, they seem OK.
Agree grip / bite when cold isnt great, and would recommend them for sprinting or even sprint racing esp. But for trackdays, they have good longevity and dont chew disks, which is good.
Sadly my car seems to be used for trackdays.
#35
I'm running Pagid RS-29s (yellow) on my fronts with bigger rotors (Zimmer) with SRF race fluid.
My rears are stock and need pads - have a set of Pagid Blues here - make sense to use them?
Will it help the bias a bit?
Its a 50/50 track/road car ie I drive to the track slowly and drive on it fast
then home once the brakes are cooled
#36
You could run the RS4-2 Blue in the rear. Not all that different than the RS4-4 Orange.
#39
For what it's worth I once had the rare pleasure of performing a quality audit at PFC's Clover, SC facility. To say that I was impressed with their operation would be to put it mildly; in fact they made me proud to be an American.
Two things of merit:
1a. I found very little to take issue with in their quality system.
1b. The things I did find were *gratefully* received, and rectified in a matter of days.
2. At the time, the typical size of a batch of friction compound was about 1500 lb/700kg; the mass of each constituent was controlled to within .5g (0.018 oz (!)).
I don't think they make a C4 street pad, else I'd run them exclusively.
