Rear axle strut bushing shot - same as spring plate?
Not a great photo but you can see the shredded rubber of the bushing on my car, to be replaced when I do the KW V3's
Photo looks like mine as well...shredded rubber in the bushing. I had no symptoms as far as driveability is concerned but I wanted to address this issue while the car was being worked on and getting realigned anyway because of new tie-rods and new H&R lowering springs getting installed.
I went with the Weltmeister and lowering springs at the same time and the ride got noticeably stiffer but I got used to it and I think it even mellowed itself out a bit after a while. I love the stance and the handling seems way crisper.
I have a friend that has a brand new OEM set that he might be willing to sell for around $1100 so I am debating whether to get them or the after market?
Please advice?
As long as you run the rod-end boots on the ERP pieces, I see no reason for them not last damn near forever. If you run them w/o boots, well, they may fail prematurely due to contamination eating away at the monoball surfaces.
Tarett sells them. Get size Large.
http://www.tarett.com/items/993-964-...oot-detail.htm
Maybe Bill Verburg can chime in on monoball longevity.
Tarett sells the spring plates as well which look identical to the ERP one's and since they also sell the boots, I would rather just go with Tarett?
When would you be done with the install, anxiously awaiting the drive impressions
Hopefully during the month of February. I'm the slowest wrench ever. However long it takes me, I plan on making an exhaustive thread w/ photos and narration of the whole process, because that's what I do.
Here's a start.
The number on the rod end is JM12T FK USA so i'm guessing is you could source replacement monoball ends if they fail and reuse the rest of the spring plate.
Here's a start.
Bushings
Has anyone had luck tracking this down?
Former Vendor
Here's how the original bushing looks like.
We've made a replacement bushing that is modeled after the original, but easy to replace and secure. The bearing and outer elastomeric layer is pressed in independently and secured using a circle clip. Check out the product page for more info.
ouch
Ouch. and the fully adjustable whole unit is 750? Not sure which is more durable. This should be a 100 bucks part. I mean a set of koni's is less for the front end.
Not that I don't appreciate the feedback and investment to make something ...but
