How to remove front fog light lens?
I'm in the middle of replacing all my exterior bulbs and am stuck trying to safely remove the fog light lens without cracking it. Any suggestions would be greatly appreciated.
That screw on the upper left will not come out. It just keeps turning.
As you can see, I've already chipped it. I thought I knew what I was doing until that happened.
If I remember correct the screw that keeps turning us just a alignment looks like you have it almost ready to remove just pry a tad bit where the 2 parts of grey plastic meet from the right and left screws you've already removed. You'll be able to access the bulbs after that. Once it's opened to access the bulbs there's 2 8mm that secure it to the actual bumper cover but if your just changing bulbs no need to worry about those:-)!! Hope I was clear in explaining!
Thanks for the prompt response guys. I was going about it all wrong. I was thinking the lens itself removed, which is probably does, but I didn't want to be doing that. I also realized that there was one more screw on the left side that was tucked further inward (just out of sight in the photo) that I wasn't considering. Once I took that left screw out, the front half of the fog light slide out nicely.
