964 Forum 1989-1994
rear spoiler update with questions
Old 10-20-2017, 01:01 PM
  #136
Lorenfb
Lorenfb's Avatar
Post
Originally Posted by bw-porsche
I did find that these relays,part number V23072 A1059 A203, seemed to be readily available in the US. Other relays may be suitable subject to the pins being similar. Good luck.
Actually, the more compatible relay has this part number: V23072 A1061 A303
The other relay part number is for an enclosed relay which would be a more difficult fit.
Old 10-20-2017, 05:12 PM
  #137
bw-porsche
bw-porsche's Avatar
The relay number I have quoted (V23072 A1059 A203) is the original open relay that was used by Porsche when 964 ‘s were first made. The one you quote I’m sure will be an enclosed type. I have just searched on eBay and found some original type available in Poland,for about 2 pounds sterling each, so I sent for 2, and the postage is reasonable too, so a winner!
Old 10-20-2017, 08:01 PM
  #138
Lorenfb
Lorenfb's Avatar
Post
The PN I provided is open case; V23072-A1061-A303.
Yes, this (A303) is on eBay and from Poland. Where's your picture of the A203?
Here is the spec:
Old 10-21-2017, 03:57 PM
  #139
bw-porsche
bw-porsche's Avatar
Photos of the original relay.
Old 10-22-2017, 05:43 AM
  #140
Lorenfb
Lorenfb's Avatar
Unless you have an actual present source it's NLA.
Old 10-25-2017, 12:43 PM
  #141
2000m2
2000m2's Avatar
I’ll just wait on your reply then.
The diagnosis from the ECU doctors:
-Defective capacitors
-Corrosion
-Broken / Damaged tracks
Currently being repaired.
Old 10-25-2017, 02:02 PM
  #142
Lorenfb
Lorenfb's Avatar
-Corrosion
Strange diagnosis based on what you posted initially:
"I declared victory over my stuck spoiler too soon! 1990 C4. It's stuck in the up position again and was like that when I bought the car. I had the 964 in the shop for some other items and had them take a look at the stuck spoiler. They ended up replacing the relay w/ p/n 964-618-142-00, which solved the problem for a few weeks. It's now stuck in the up position again. Manual switch does not do anything."
This is interesting:
"which solved the problem for a few weeks. It's now stuck in the up position again."
Based on the above diagnosis, it's surprising the unit ever functioned!
Old 10-25-2017, 11:36 PM
  #143
2000m2
2000m2's Avatar
These spoilers are all very strange as they get older. Electrical gremlins, I suppose. Certainly not my area of expertise, but I sure hope this solves the problem. I should have it back next week.
Old 10-26-2017, 12:39 AM
  #144
Lorenfb
Lorenfb's Avatar
Not really! Over the years I've tested & rebuilt (only as needed), most mis-diagnose
their problem as being the unit itself versus a wiring/switch/connection.
Do a Google search;
http://www.google.com/search?q=911+6...&start=10&sa=N
and find Parts as you scroll down.
Old 10-27-2017, 01:15 PM
  #145
Spokes
Spokes's Avatar
I had booked marked this thread to refer back to the resister / speed charts by mojorizing, #52 #55. They have disappeared? Can someone or mojorizing repost the charts again. Much appreciated.
Old 10-27-2017, 03:38 PM
  #146
mojorizing
mojorizing's Avatar
Good Catch - I reposted the charts on #52 and #55
Old 10-27-2017, 07:32 PM
  #147
Spokes
Spokes's Avatar
Thanks. I cut & pasted them into a file
Old 11-02-2017, 08:01 PM
  #148
2000m2
2000m2's Avatar
I got the module back yesterday and installed it. I was able to close the spoiler with the manual switch. I just went for a drive to make sure everything functions as expected while driving and it's all good. Knock on wood that this solves it, so I can move on to other projects.
Old 11-02-2017, 11:59 PM
  #149
Spokes
Spokes's Avatar
Perfect for me. Replacing the 180K resistor with a 56K resulted in the spoiler extending at 120kph and retracting at 50kph.
Old 01-24-2021, 10:03 AM
  #150
stevensivak
stevensivak's Avatar
I take it this entire discussion does not relate to 993's?
Quick Reply: rear spoiler update with questions
