CHEAP - Brand new replica Big Reds...
#46
Based on ordering at least four sets of standard pads which fit 964 front and rear (4 pots) and 993 rears, these are working out at about £132 per set:
Standard size pads - HB170 blue
Based on ordering at least two sets of Big red pads (also fit 928 big blacks), these are working out at about £211 per set.
Big red/black pads - HB184 blue
This includes shipping to me and import tax that I have to pay on arrival. I guess that sending the pads on to you by post would add about £15 to your total bill.
This is all based on:
Boxsey: 2 X HB170 blue
Cheeksyboy: 1 x HB184 blue, 1 x HB170 blue
Frank: 1 x HB184 blue, 1 x HB170 blue
If there's more than this I would check first to see if we can get more discount.
#47
Also just had an interesting chat with Peter of GT One...
He was chatting to an ex parts guy from Design 911 recently... apparently their Design Tek exhausts are manufactured in China.... which obviously doesn't give me much confidence in Design Tek callipers priced at £399 for the pair.
Whilst a Chinese quality exhaust is fine - cheap callipers must be a safety hazard.
My mind is starting to spin!
Thanks for the feedback. So would these fit for the front Big Red callipers?
http://www.ebay.co.uk/itm/EBC-FR-GRO...#ht_528wt_1398
In the listing they say to be used with 993 Turbo discs and pads.
http://www.ebay.co.uk/itm/Brake-Cali...ht_2686wt_1398
What discs do you have on the front? 928 dics?
Frank, you need to call me if you are serious about this brake mod or read up on everything that Bill has said. You will need 928 rotors on the front not 993 as offset different. You will also need 993 rear calipers or the bias will be out. And the big thing is as soon as you split the brake system it will need bleeding by a Porsche garage as can not be done properly at home. trust me I have tried!!!
#49
Frank,
Some of their exhaust stuff clearly states made in Germany in the description
http://www.design911.com/Porsche/997...-cma81-ct1372/
If you are concerned about it, call them and ask, personally I would want to qualify any 2rd hand info from an 'ex' employee
#51
Why don't you try and get hold of a set of big blacks (off 928 GTS if my memory serves me right) as they're less glamorous than the reds and thus often a lot cheaper!
They're not exactly the same (can't remember what the difference was, sorry), but they take the same pads.
I'll have a look at exactly what parts I've got and PM you tonight when I get home.
#52
Frank,
#53
Frank,
I know that was my thinking, Design Tek are German... but then again a lot of these companies do have parts manufactured in China. Not that, that is always a bad thing - but in my eyes there's an element of risk to a product that could have been manufactured even in part in China.
Is it a risk I really want to take with a braking system? Anyway the reason I posted about it is because I'm speculating. Just wanted to see if someone may have thought the same or different?
But your right I'll call them up about it...
I have 928 x-drilled discs on the front, standard on the rear.
#54
Investigation complete....
Peter was telling me that he constantly gets phone calls/ emails from Chinese companies that can remanufacture Porsche parts at way cheaper prices...
If you look at ' DesignTek ' and ' Design911 's websites you'll notice they are both made by the same company, have a very similar layout and their checkout procedure is the same...
I called up 'Design911' again. Turns out 'Design Tek' is their very own brand of aftermarket parts... Apparently the company that manufacturers they're aftermarket parts is based in Denmark. I asked the name of the Danish company to which he replied "It's irrelevant"....
So Design911/ Design Tek exhausts are made in Germany or Denmark? Is every product made under the 'DesignTek' brand manufactured by different companies?
#56
Its not unusal for a comany to have products manufactured in more than one location but marketed under one name
Boxsters used to be built in Finland not Germany for instance.....
#57
If for example Brembo manufactures parts in Denmark I would trust them but DesignTek isn't as much of a industry leading brand - I just don't know...
As said, if it were window wipers I wouldn't care but brakes I'm more concerned, what would you do?
#58
If there's going to be a worry at the back of your mind that you've made a bad decision by buying non Porsche/Brembo, you're better off buying the real thing:
993 turbo calipers
OK they will work out at nearly twice the price but at least you know that you've got the genuine article. Alternatively you could hold out for some second hand ones but from my experience, even with normal calipers, the additional cost of refurbing used ones (they always need it) puts the final price up near the cost of new ones.
993 turbo calipers
#59
Sure but they were approved to be built in Finland by Porsche themselves.
My take is
D911 are probably the biggest Porsche parts suppliers in the UK
Most of the feedback Ive seen about them is good (as is my experience with them for the bits Ive bought) unlike some other parts suppliers further North shall I say
Would I buy own branded brake calipers from them?, probably, if I couldnt get a decent S/H set for the right price.
I would probably ask for confirmation of where they are manufactured first if that is a concern though
Ring Matthew at Type 911 (he stocks them also) and ask him, he only resells them (at a mark up) but may be more forthcoming
http://www.type911shop.co.uk/shop/ar...6aid%3D1939%26
Even if they are made in China, they're not knock off's pretending to be something they're not
#60
Here's a source for the 928 GTS solid discs, around £220 each
http://www.promaxmotorsport.co.uk/ca...63-brakes.aspx
The 965 drilled discs are the same dimensions but are half the price. I've done some googling and the drilled rotors do seem to crack when given stick.
Interesting article here on brake upgrades for the 968 which uses similar front brakes to 964s
http://www.porsche968uk.co.uk/techni...968-brakes.htm
From this article it looks like the 993RS or Turbo discs are usable but the adapters will either need flipping or fettling to work properly.
